Après pas mal de sujets ouvert au sujet des huiles moteur, voici un sujet qui permettra de regrouper toutes les informations vérifiées :
-== Recommandations officielles ==-
On retrouve ici, la liste (par ordre alphanumérique) des recommandations officielles et les standards du constructeur FIAT/FCA.
Fiat 9.55535-D2
Qualification for Diesel engine lubricants with standard characteristics.
Fiat 9.55535-DS1
ACEA C2 based, 0W30 viscosity, mid-SAPS engine oil for the latest diesel engines of the Fiat Group (Fiat, Alfa-Romeo, Lancia).
Fiat 9.55535-G1
Qualification for gasoline engine lubricants granting fuel economy and extended drain.
Fiat 9.55535-G2
Qualification for gasoline engine lubricants with standard characteristics.
Fiat 9.55535-GS1
ACEA C2 based, 0W30 viscosity, mid-SAPS engine oil for the latest gasoline engines of the Fiat Group (Fiat, Alfa-Romeo, Lancia).
Fiat 9.55535-H2
Qualification for gasoline engine lubricants, granting high performances and high viscosity at high temperatures. OEM recommended product also meets API: SM, ACEA A3-04/B3-04.
Fiat 9.55535-H3
Qualification for gasoline engine lubricants granting very high performances.
Fiat 9.55535-M2
Qualification for lubricants with extended drain. OEM recommended product also meets ACEA B3-04/B4-04, GM-LL-B-025.
Fiat 9.55535-N2
Qualification for lubricants with a very good characteristics for turbocharged engines, Diesel and gasoline, with extended drain. Minimum requirement is ACEA A3/B4-04.
Fiat 9.55535-S1--> Pour nos moteurs diesel 1.6 MultiJet 115cv et 120cv.
Qualification for Diesel and gasoline engine, with exhaust treatment system, lubricants, granting fuel economy and extended drain. OEM recommended product is also approved to ACEA C2.
Fiat 9.55535-S2 --> Pour nos moteurs essence 1.4 16V 95cv et 1.4l T-Jet 120cv.
Qualification for Diesel and gasoline engine, with exhaust treatment system, lubricants, with extended drain. OEM recommended product also meets: ACEA C3-04, MB 229.51 and API: SM/CF.
Fiat 9.55535-S3
Pas d'informations
Fiat 9.55535-T2 --> Pour nos moteurs bicarburants Essence/GPL 1.4 T-Jet 120cv.
Pas d'informations
Fiat 9.55535-Z2
Pas d'informations
Sources :
Fiat and Petronas
Fiat Oil Specifications
Notice d'entretien TIPO 4DOORS (fr)
Notice d'entretien TIPO 5DOORS / TIPO STATION WAGON (fr)
-== Huiles recommandées ==-
Sources :
Petronas Lube Recommender (France)
Petronas Lube Recommender (Belgique)
-== Huiles compatibles ==-
On retrouve ici, la liste des huiles compatibles et adaptées aux normes et standards du constructeur FIAT/FCA.
- Pour nos moteurs bicarburants Essence/GPL 1.4 T-Jet 120cv :
- Blu Synthetic 5W-40 Technician Series FS
- CHAMPION NEW ENERGY 5W40 GAS
- Eurol Fluence 5W-40
- Eurol Turbo DI 5W-40
- Dinoil - SAE 5W/40 GAS LPG METHANE
- Duglas Oil GTx POWERGAS 5W-40
- I.G.A.T. PLATIN MF SAE 5W-40
- LNX Synth LA-C3 SAE 5W-40
- MISOIL SYNTECH C3 5W-40
- OWS Hyper Max SAE 5W-40
- ROWE HIGHTEC MULTI FORMULA SAE 5W-40
- Siroil Extrasint SAE 5W-40 GAS
- Wolf Oil MULTIGRADE SN/CF SAE 5W40 GAS
- WOLF VITALTECH 5W40 GAS
- Wolver UltraTec 5W-40
- Zanoil Velox 8000 PLUS 5W-40 HC Synthesis
Sources :
Quale olio? Quando cambiarlo? (metanoauto.com)
Recherche achat huiles moteur :
Huiles norme Fiat 9.55535-S1 (Idealo.fr)
Huiles norme Fiat 9.55535-S2 (Idealo.fr)
Huiles norme Fiat 9.55535-T2 (Idealo.fr)
