[ TUTO ] Menu caché uconnect 7 et 5 (engineering mode) + Réf. autoradio
Aladin
Re: [ TUTO ] Menu caché uconnect 7 et 5 (engineering mode)
non pas la honte tu appuie sur les 3 boutons en meme temps enfoncer avec contact allumer et tu reste appuyer sa va s afficher apres
Ah, je l'ai fait contact coupé !
Par contre, tu le fait avec le Uconnect pas encore allumé ?
Aladin
u connect allumer contact mis moteur coupe et t appuis silmutane sur les 3 boutons comme le poste au debut
Merci, ça a marché cette fois ! Merci
J'ai donc,
dans Target Main Data > Main screen
Hardware Release
0.32.4.1
Firmware Release
0.0.0.2
Production date
2017-04-23
J'ai donc,
Hardware Release
Firmware Release
Production date
Et, je ne sais pas si j'ai le DAB car c'est en grisé...
J'ai aussi le Menu Radio: FMDAB threshold
Aladin
Oui mais tu dois regarder quel version que tu as refait le et va dans général il faut que ta la version v22.
Tu as la dernière en date mais apparemment une nouvelle viens de sortir il sont en train de faire un rappel
danielstuart14
- véhicule : Fiat Argo Drive 1.3
Hi, sorry for replying in english. (I'm brazilian, and I really didn't want to use google translator)
Here in Brazil, Fiat just released a new car, named Argo, that is based on the European Tipo. (And even has the same Uconnect 7)
I tried your tutorial and it worked fine! My version is 22.00.56.02
The problem with our Uconnect is that it doesn't have any navigation software, not even as an additional. But going through the Engineering menus, I found that it does have GPS built-in (I checked the values at "Pos Eng Menu"), and when doing a dump of the Radio Proxy and DEVLog, I found that it has the NAV disabled only by software.
So, if someone with a GPS enabled Uconnect 7" make a dump of the Radio Proxy and DEVLog and post here, I'd be very glad, then I can check the differences between NAV-enabled and NAV-disabled Uconnects. I think we can change the variables through OBD2 with the right software, and then, unlock not only NAV but many more features.
I'm going to attach my dump (I got it doing: Saving Of -> Radio Proxy & DEVLog. Keep in mind that when you are inside "Saving Of" menu, you have to scroll the "Browse / Enter" button to navigate and click on the same button to select. Also, you need a pendrive attached)
- Dump_Fiat_Argo_2017.zip
- (4.8 Kio) Téléchargé 638 fois
Hi Danielstuart14,
On my Tipo, I've the Uconnect 5"... Sorry.
But, not possible for your Fiat mecanician to unlock navigation on your Uconnect 7" ?
Utilisateurs parcourant ce forum : Baidu [Spider] et 1 invité
