[ TUTO ] Menu caché uconnect 7 et 5 (engineering mode) + Réf. autoradio
Re: [ TUTO ] Menu caché uconnect 7 et 5 (engineering mode)
Messagepar luca6182 » mar. 1 août 2017 15:47
danielstuart14 a écrit :Hi, sorry for replying in english. (I'm brazilian, and I really didn't want to use google translator)
Here in Brazil, Fiat just released a new car, named Argo, that is based on the European Tipo. (And even has the same Uconnect 7)
I tried your tutorial and it worked fine! My version is 22.00.56.02
The problem with our Uconnect is that it doesn't have any navigation software, not even as an additional. But going through the Engineering menus, I found that it does have GPS built-in (I checked the values at "Pos Eng Menu"), and when doing a dump of the Radio Proxy and DEVLog, I found that it has the NAV disabled only by software.
So, if someone with a GPS enabled Uconnect 7" make a dump of the Radio Proxy and DEVLog and post here, I'd be very glad, then I can check the differences between NAV-enabled and NAV-disabled Uconnects. I think we can change the variables through OBD2 with the right software, and then, unlock not only NAV but many more features.
I'm going to attach my dump (I got it doing: Saving Of -> Radio Proxy & DEVLog. Keep in mind that when you are inside "Saving Of" menu, you have to scroll the "Browse / Enter" button to navigate and click on the same button to select. Also, you need a pendrive attached)
Traduction:
[Quote = "danielstuart14"] Bonjour, désolé de répondre en anglais.
Ici au Brésil, Fiat vient de sortir une nouvelle voiture, appelée Argo, basée sur le type européen. (Et même le même Uconnect 7)
J'ai essayé votre tutoriel et ça a bien fonctionné! Ma version est 22.00.56.02
Le problème avec notre Uconnect est qu'il n'a pas de logiciel de navigation, pas même en tant que complément. Mais en passant par les menus d'ingénierie, j'ai constaté qu'il avait un GPS intégré (j'ai vérifié les valeurs dans "Pos Eng Menu"), et lors d'un déchargement de Radio Proxy et DEVLog, j'ai constaté qu'il avait la NAV désactivée Uniquement par logiciel.
Donc, si quelqu'un avec un GPS activé Uconnect 7 "fait un vider de Radio Proxy et DEVLog et publie ici, je serais très content, alors je peux vérifier les différences entre les Uconnects NAV-enabled et NAV-disabled. Je pense que nous Peut changer les variables via OBD2 avec le bon logiciel, puis débloquer non seulement NAV, mais bien d'autres fonctionnalités.
Je vais attacher mon dump (je l'ai fait en train de faire: Sauvegarde de -> Radio Proxy & DEVLog. Gardez à l'esprit que lorsque vous êtes dans le menu "Sauvegarde de", vous devez faire défiler le bouton "Parcourir / Entrée" pour naviguer Et cliquez sur le même bouton pour sélectionner. De plus, vous avez besoin d'un pendrive attaché)
Messagepar Raoul » mar. 1 août 2017 15:54
On n'est pas plus avancé... :? Comment fait on: pour vider le Radio Proxy et DEVLog :?:
josephp
véhicule : Fiat Tipo 5p 1.6MJet
Messagepar josephp » ven. 4 août 2017 09:30
Hey danielstuart14,
Here are the dumps.
Versions :
Base line : 21.01.18.01
Hardware release : 0.32.4.1
Firmware release : 0.0.0.2
Production Date : 2014-04-01 (date of firmware release, not the car manufacturing date)
Uconnect Live : 8.6.0
Dump_Fiat_Tipo_Hatchback_2017.zip
(5.92 Kio) Téléchargé 1657 fois
Fiat Tipo 5p Gris Maestro EasyBusiness (alias Business+) 1.6 Multijet 120ch DCT
danielstuart14
véhicule : Fiat Argo Drive 1.3
Messagepar danielstuart14 » sam. 5 août 2017 23:03
josephp a écrit :Hey danielstuart14,
Here are the dumps.
Versions :
Hi, thank you!
Yes, my guess was correct. Both "Nav Repetition" and "Nav Presence" vars must be set as "0x1" on the vehicle proxi.
But, our NavMapVersion (DEVLOG dump) isn't the same. (Probably mine is Global/LATAM)
Image Image
I know only one software that can change Proxi variables (MultiECUscan), but it doesn't support the Argo nor the newer Tipos (With the Uconnect 7"). I'll try borrow the scanner from my Dealer, it should have all these functions, since MultiECUscan is a reversed engineer version of the official Fiat scanner.
Also, @josephp, I found a DTC error (AKA: OBD error) on your log, I'd recommend you to ask your mechanic to scan your car and see what it really is. Check the picture:
Messagepar luca6182 » dim. 17 sept. 2017 20:58
Il y a une mise à jour qui circule sur le net (j'en parle également dans le sujet concernant les mise à jour (page 19)
viewtopic.php?f=10&t=379
22.00.63.01
2.86 gb
Aucun risque à priori car ci pas compatible avec votre autoradio un message apparaît et ne lance pas la mise à jour
https://mega.nz/?_escaped_fragment_=0mR ... CyFdMDV_0Q
Je vais tester dés que possible sur mon autoradio uconnect 7 nav + caméra de recul 316 (sans dab !7Q9, android auto et apple car play !8EW)
et encore la je parle que de l'uconnect 7
Également le câblage, l'antenne et le port usb sont différent selon les options
Modifié en dernier par luca6182 le lun. 18 sept. 2017 09:08, modifié 7 fois.
Messagepar luca6182 » dim. 17 sept. 2017 21:25
Voici la liste complète:
la premières colonne 1,2,3,4 et 5 va avec l'image juste au dessus
La deuxième colonne c'est la référence FIAT genre si vous allez chez FIAT c'est cette référence qu'ils vont donner
(TC3V, TC2V et TCSW) signifie la carrosseries de la Tipo
EX: D19634, C20083,... BREF tout ce qui est à la fin de la référence du modèle c'est une référence pour savoir qu'elle version de mise à jour est fournie à l'achat
les options Ex: 7Q9 avec Dab - !7Q9 sans DAB
Radio
1 735637868 APPAREIL AUTO-RADIO 6ZE
1 735637869 APPAREIL AUTO-RADIO 7BY
1 735637870 APPAREIL AUTO-RADIO 6ZF
1 735637871 APPAREIL AUTO-RADIO 7BZ
Radio 5"
2 735641813 APPAREIL AUTO-RADIO 7HZ C19634
2 735654652 APPAREIL AUTO-RADIO 7HZ + TC3V D19634, C20083
2 735641815 APPAREIL AUTO-RADIO 7J0 C19634
2 735654653 APPAREIL AUTO-RADIO 7J0 + TC3V D19634, C20083
2 735652554 APPAREIL AUTO-RADIO (TC2V, TCSW) + 7HZ D19634, C20083
2 735652554 APPAREIL AUTO-RADIO 7HZ + !RSW D20083, C21072
2 735652555 APPAREIL AUTO-RADIO (TC2V, TCSW) + 7J0 D19634, C20083
2 735652555 APPAREIL AUTO-RADIO 7J0 + !RSW D20083, C21072
2 735641814 APPAREIL AUTO-RADIO !5DE + 6RW + TC3V
2 735654663 APPAREIL AUTO-RADIO 98Q + TC3V C20083
2 735661494 APPAREIL AUTO-RADIO 98Q + TC3V D20083
2 735658282 APPAREIL AUTO-RADIO 97W + TC3V
2 735661517 APPAREIL AUTO-RADIO 7HZ + RSW C21072
2 735661517 APPAREIL AUTO-RADIO 7HZ D21072
2 735661518 APPAREIL AUTO-RADIO 7J0 + RSW C21072
2 735661518 APPAREIL AUTO-RADIO 7J0 D21072
Radio 5"
3 735654654 APPAREIL AUTO-RADIO 7W0 + TC3V C20083
3 735661495 APPAREIL AUTO-RADIO 7W0 + TC3V D20083
3 735641817 APPAREIL AUTO-RADIO 7VX C19634
3 735654655 APPAREIL AUTO-RADIO 7VX + TC3V D19634, C20083
3 735641818 CONNECT 7J1 C19634
3 735654656 APPAREIL AUTO-RADIO 7J1 + TC3V D19634, C20083
3 735641819 CONNECT 7J2 C19634
3 735654657 APPAREIL AUTO-RADIO 7J2 + TC3V D19634, C20083
3 735652557 CONNECT (TC2V, TCSW) + 7J1 D19634, C20083
3 735652557 CONNECT 7J1 + !RSW D20083, C21072
3 735652558 CONNECT (TC2V, TCSW) + 7J2 D19634, C20083
3 735652558 CONNECT 7J2 + !RSW D20083, C21072
3 735652556 CONNECT (TC2V, TCSW) + 7VX D19634, C20083
3 735652556 CONNECT 7VX + !RSW D20083, C21072
3 735661520 CONNECT 7J1 + RSW C21072
3 735661520 CONNECT 7J1 D21072
3 735661521 CONNECT 7J2 + RSW C21072
3 735661521 CONNECT 7J2 D21072
3 735661519 CONNECT 7VX D21072
Ecran Radio 7"
4 735652559 PROTECTION (TC2V, TCSW) + 7Q8 + !9PU
4 735652559 PROTECTION (TC2V, TCSW) + 7Q9 + !9PU
4 735652559 PROTECTION (TC2V, TCSW) + 7QA + !9PU
4 735652559 PROTECTION (TC2V, TCSW) + 7QB + !9PU
4 735652559 PROTECTION (TC2V, TCSW) + 7QC + !9PU
4 735652559 PROTECTION 97X + TC3V
4 735652559 PROTECTION 97Y + TC3V
4 735670900 PROTECTION (TC2V, TCSW) + 7Q8 + 9PU
4 735670900 PROTECTION (TC2V, TCSW) + 7Q9 + 9PU
4 735670900 PROTECTION (TC2V, TCSW) + 7QA + 9PU
4 735670900 PROTECTION (TC2V, TCSW) + 7QC + 9PU
Radio 7"
5 52019282 CONNECT (TC2V, TCSW) + 7QA + GSX C20208
5 52019283 CONNECT (TC2V, TCSW) + 7QC + GSX C20208
5 52019284 CONNECT (TC2V, TCSW) + 7QB + GSX C20208
5 52057021 APPAREIL AUTO-RADIO (TC2V, TCSW) + !316 + 7Q8 + GSX C20208
5 52057022 APPAREIL AUTO-RADIO (TC2V, TCSW) + 316 + 7Q8 + GSX C20208
5 52057023 APPAREIL AUTO-RADIO (TC2V, TCSW) + 7Q9 + GSX C20208
5 52056359 CONNECT TCSW + 7QC + GSX C20208
5 52056359 CONNECT (TC2V, TCSW) + !8EW + 7QC + GSX D20208
5 52071363 CONNECT (TC2V, TCSW) + 7QB + 8EW + GSX D20208
5 52071362 CONNECT (TC2V, TCSW) + 7QC + 8EW + GSX D20208
5 52071361 CONNECT (TC2V, TCSW) + 7QA + 8EW + GSX D20208
5 52065360 CONNECT (TC2V, TCSW) + !8EW + 7QB + GSX D20208
5 52065358 CONNECT TCSW + 7QA + GSX C20208
5 52065358 CONNECT (TC2V, TCSW) + !8EW + 7QA + GSX D20208
5 52065355 APPAREIL AUTO-RADIO TCSW + !316 + 7Q8 + GSX C20208
5 52065355 APPAREIL AUTO-RADIO (TC2V, TCSW) + !316 + !8EW + 7Q8 + GSX D20208
5 52065356 APPAREIL AUTO-RADIO TCSW + 316 + 7Q8 + GSX C20208
5 52065356 APPAREIL AUTO-RADIO (TC2V, TCSW) + !8EW + 316 + 7Q8 + GSX D20208
5 52056357 APPAREIL AUTO-RADIO TCSW + 7Q9 + GSX C20208
5 52056357 APPAREIL AUTO-RADIO (TC2V, TCSW) + !8EW + 7Q9 + GSX D20208
5 52071358 APPAREIL AUTO-RADIO (TC2V, TCSW) + !316 + 7Q8 + 8EW + GSX D20208
5 52071359 APPAREIL AUTO-RADIO (TC2V, TCSW) + 316 + 7Q8 + 8EW + GSX D20208
5 52071360 APPAREIL AUTO-RADIO (TC2V, TCSW) + 7Q9 + 8EW + GSX D20208
5 52063450 APPAREIL AUTO-RADIO 97X + TC3V
5 52063451 CONNECT 97Y + TC3V
Modifié en dernier par luca6182 le dim. 17 sept. 2017 22:06, modifié 2 fois.
Messagepar Michel » dim. 17 sept. 2017 21:50
luca6182 a écrit :Il y a une mise à jour qui circule sur le net
22.00.63.01
2.86 gb
Par contre sais-tu si c'est la mise à jour firmware de la campagne de rappel du Uconnect 7" pour le correctif du bug de l'écran noir?
Messagepar luca6182 » dim. 17 sept. 2017 21:54
22.00.63.01
2.86 gb
je l'ai télécharger et a l'intérieur du fichier zip j'ai un .txt
la date de la mise à jour est 13/07/2017
et c'est indiqué VP2 ce qui veut dire PACK TECH
Et également 356/358/359 référence des châssis tipo
Software Loading CD for MMP based units (c) Continental Automotive GmbH Wetzlar
TreeBuilder version 04.06.00.00 is used.
#CD:22.00.63.01
#DATE:2017-07-13
#Project: VP2
#Author: uid65106
#Abbr:
#UID:
#Steckbrief: VP2R-FGA-520
#MediumType: full
#Carlines: 29;31;33;36
#CommentStart:
USB SWL Medium for VP2R - full update for Fiat 356/358/359 and Chrysler MP variants including Bootstrap
#CommentEnd:
#LogData1:LogData1 test string
#LogData2:LogData2 test string
#LogData3:LogData3 test string
#LogData4:LogData4 test string
#VDOLogData:VDOLogData test string
#SysIntVersion:2.0.0.0
Modifié en dernier par luca6182 le dim. 17 sept. 2017 22:19, modifié 1 fois.
Messagepar luca6182 » dim. 17 sept. 2017 22:08
Je teste demain et si ca marche je reviens vers vous avec photo à l'appui et petit TUTO
Re: [ TUTO ] Menu caché uconnect 7 et 5 (engineering mode) + Réf autoradio
Messagepar Michel » dim. 17 sept. 2017 22:35
Bon je viens enfin de réussir à accéder au menu cacher et j'ai jeter un œil à la version de ma dernière mise à jour qui n'est autre que celle que tu viens de trouver sur le net! ;)
Donc tu peux y aller sans soucis sur ton Uconnect, ça va te résoudre tes bugs d'écran noir au démarrage et le plantage système en cours de fonctionnement... en tout cas depuis mardi dernier je n'ai plus de problèmes de ce genre avec mon Uconnect LIVE 7"! ;)
